When at full throttle, it feels like 3rd is lugging half way through the gear, then when it shifts up to 4th, it pulls strong again. I didnt have the monitor plugged up at the time so i dont know if it was 4th it shifted up to or if it was just the t/c locking in 3rd but my question is if it was any type of malfunction aside from just not being learned to full throttle shifts, would i have a code.
I installed a transgo jr myself almost a year ago and felt pretty good about the job, as far as everything being installed correctly and the reinstallation of the valve body going smooth. Im curious that if there was any issue that had anything to do with the transgo jr, wouldnt there be a code and wouldnt it be likely that the tranny would not even operate correctly under normal driving conditions? Under normal driving conditions, the transmission shifts smooth through all the gears and i have not had any codes.
I am hoping that a problem with the transgo jr would be obvious if anything was not right and i would have some code. If so, this may just be an issue of the transmission not being used to full throttle. I rarely accelerate hard in the truck and that is what leads me to hope there is no mechanical issue. Thanks guys.
