Hi,
I'm having some problems with my allison. It doesn't want to shift into some of the gears and the indicator light for the gear doesn't light up around all of the different gears. The trans is an ATS trans.
When driving, it just started clunking when you put it into gear. And not all of the gears work; as in, it won't shift into 5th.
The indicator lights also don't light up correctly. It doesn't indicate when you're in D or 2. The rest of them do work correctly though.
Any suggestions? Thanks.
