So I had a issue with a build that caused a bell housing bolt to fall out and mess up my bell housing and torque converter.... So I pulled the trans replaced all the gaskets and bolts bellhousing converter with a new tcs triple disc from MA and filled it up with 18 quarts since I did new fleece lines and a bigger cooler for the trans so it was dry but I did put a quart in the converter before putting it in. Then I went to shift into reverse it worked went to go into drive no luck it keeps saying range inhabited but it was going into drive this morning then stopped after I shut it off then when I went to throw it in reverse it started loping so Idk what to do I order a nsbu for it hoping this is the issue Idk if my grammer sucks forgive me please help.
