shift range inhibited during heavy throttle use
ghconcrete
Feb 15, 2015
minnesota
my 03 dirty will lock into 3rd gear and show shift range inhibited on cluster during heavy throttle use, loaded or empty. have to pull over, shut down, and restart engine to reset. often requires multiple shutdowns and restarts
ghconcrete
Feb 15, 2015
minnesota
fuel filter is fine. didn't use code reader the message shows up on the gauge cluster. if anyone can figure this out i would like to hear it. both the ecm and tcm were replaced and a new transmission was installed by allison technicians.
pgr11
114
Hesperia, CA
Mike is telling you to use a scanner to read what codes come up. What shows up on the dic isn't enough information. When you have the codes he can help you figure out the issue
ghconcrete
Feb 15, 2015
minnesota
ok just got back from the shop, transmission codes: P0848 Transmission pressure switch solenoid D circuit high; P0875 transmission pressure switch reverse circuit; P0701 transmission control system out of range
295PRO
Jan 30, 2015
Have the same issue. Code I got is P0735 5th gear ratio incorrect.
Any help would be helpful.
15,681
Sounds like a voltage problem. p0701 is no pressure. Since you've done the trans we will assume it has clean filters and not blocked. Check ign. switch and voltage to trans. Check it with KOEO and running. It better have 12V or better to solenoids.
