When are you guys shifting? I did some searches and didn't find any in depth info. 3500rpm? Also what Engine/Turbo combo?
Thats a healthy number! Have you done anything to the stock valve config?
Not that I know of. if you break your input shaft you are going to over rev. how far you over rev depends on what you have the limiter set at.
I always figured if it was set at 3500 vs 4200 it would keep it a from over reving as much, but yea she is going to over rev. I was having issues spinning in 2nd and 3rd gear but didn’t want to raise the rev limiter way up b/c of this. Guess if you are going to let the valves get friendly with the pistons it really doesn’t mater that much. I'm sure one day Ill find this out too...The limiter doesn't do beans when you snap something in the trans. Unless maybe you kept in it and let it catch itself. You can see right around 5k within a couple frames in a log when it breaks. Not that I would know :rofl:
