how come shift points dont happen when they are cammanded ? for example 3-4 shift cammand is 3750 rpm ... wich from logs happens at 62 mph .... cammand mph had to be lowered to 56 mph to make that shift happen and when it did it was slow and kinda drawn out , same with the 4-5 . all of them dont really match but the others are very sharp crip shifts ? wonder if i am doing something wrong ?
on my datalogs it's always appeared that both rpm and mph have to be met before it will shift. So I started just working with the rpm mostly, as that's the critical part to me.
On my truck 3453 rpm in third is 54 mph. To reach 3750 rpm that's a 6% increase, and the mph would only be 57 or so. So it appears that if you had it set at 62 mph then it would not be shifting until beyond 3750 rpm.
Of course tire size has everything to do with it, but since you said to shift at 3750 you had to put 56 mph in, it seems we're real close to the same overall diameter on mine (I have 265/60-17's).
On my 3-4 wot upshift I left the mph at 46 (which I believe was stock), but moved the shift rpm to 3425 rpm (old single turbo tune). It would hit a max of 3453 rpms or so by the time it made the shift, so very close.
I would try lowering the mph and setting the rpms maybe 50 below the max you want it to hit (to allow for shift time), and see how it works. The above numbers assume your converter is locked also.
Jody
