Shavings in oil cooler
lexa
31
Moscow
Hi All!
I`ve bought used oil filer housing with cooler. Found pretty much shavings in deep of cooler and housing valves holes. Shavings seems is copper.
Is this from journal bearings?
Is it possible to clean cooler or I should to buy new one?
-Alex
9,905
151
86 the cooler. Safest route. Every diesel engine I have ever worked on if the engine has a failure and gets solid contaminants through the oil, most manufacturers recommend to replace the cooler too.
lexa
31
Moscow
Thanks for advices! You probably saved my engine:thumb:
Could you tell me why somebody delete this cooler? I`ve seen the oil cooler delete kits.
