LLY Issues:
First.. Yes the fuel filter has been changed..Often after the truck has been sitting overnight etc. and i go to start it .. it starts runs great for about 8seconds.. then immediately dies. I had a new O-ring put in somewhere in the bleeding system I think under the bleeder pump(been a little while ago). Also when it starts normally it still seems to crank longer than it should. Also noticing a small lope at idle. Like i said i've changed the fuel filter. So im thinking Fuel Rail Pressure Regulator???? Is there a way to check the FPR with my EFI Live... help me out.. Thanks a lot...
