Have abs and red brake light on dash on and service brake system on the dic. Comes on as soon as the key is turned on and doesn't go off unless I clear abs codes- there are no abs codes in it though. This started a couple days ago when I had an engine dying issue, had a fault P2510, ended up finding underhood fuse panel corroded. Replaced fuse panel and fixed the dying issue, abs issue still present. I have cleaned the ebcm ground wire, checked voltage at ebcm connector, checked abs faults-none. Not sure where to go next, possibly have the ebcm reprogrammed?
