Service 4WD on DIC - Feels like its hitting a rev limiter
joshua202008
Jul 10, 2014
3
So I am having trouble with my truck right now. When I try to jump on it, my truck "falls flat on its face" like its hitting a rev limiter. When it does this, it is popping up a "Service 4WD" message on the DIC and is flashing a check engine light that only flashes a few times and then goes out.
This just started happening after I did the installation of a bunch of after market parts (check mods in signature).
So far I have scanned it with a few items (including a tech 2) and here are the following codes I have received over time (not all at once and not in any order):
-C0569
-P0606
-P0561
-U0102
-U0140
-U0141
So far I have tried the Manual Relearn For the TCCM using the 4WD selector switch, but it didn't work. I have also taking it to a shop and they couldn't tell me anything, but diesels weren't their specialty either.
I have attached a datalog for reference, if that might help diagnose it better.
PLEASE HELP!!!! I have a ton of money into this truck and I have yet to feel the true potential of this beast due to this issue!
  • E35_0002.zip
GSXRTURBO1
Feb 10, 2015
139
Detroit MI
This is a longshot, but check all your connectors to make sure a pin hasn't backed out somewhat. It could be making enough of a connection to work until you use full throttle. Just a thought.... good luck, keep us posted.
