Sensor off lly to lbz bridge
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
ImageUploadedByTapatalk1362669319.722168.jpg I'm putting lbz runners and y bridge on in place of the lly stuff. There isn't a spot for this sensor on the lbz runners.. Do I need to fab a spot up for it on the lbz runners.. Does it matter where I put it?? I was thinking of putting it in the y bridge as long as the wires reach. Thanks
fullpullalex
Moar Powah Pleez
Feb 22, 2013
46
Mass
Others have put a piece of threaded pipe with a hose barb on the end and put a piece of hose on the and then put the sensor in that. Anywhere that can properly read boost pressure should suffice.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Why are you putting LBZ runners on? Tony Burkhard has proven they dont flow any better, and says that they actually could be slightly worse because of the turbulence generated with the bigger manifold openings...
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Yep. That's exactly what I did. Just put a hose barb fitting in the Y bridge, then run a piece of hose to the LLY MAP sensor. Just take the little orange gasket off then end of the sensor and connect the hose. Use a couple of worm gear clamps to hold it on.
