LMM: Seem to be loosing fuel prime
jsborn
Dec 2, 2010
Southeast Georgia
I have a 2009 Chevy 2500 HD , bone stock , 132000 miles. Every now and then (it has happened twice) after I have been driving maybe 30 miles or so and park and shut it down when I return after 30 min to an hour or so the starter just spins the engine, sounds like no fuel. First time I had 1/4 a tank of fuel second time 3/4 tank.
I raise the hood pump the primer on top of the filter until it firms up and it will usually start like normal. Some times I have to repeat the pump up a second time before it will fire up. This has happened with different filters over a period or maybe a year.
Any suggestion as to what is causing this and how to repair it.
Thanks in advance for any help.
jlawles2
1,054
Danbury, TX
Filter head itself could be leaking. You can buy a rebuild kit or a new one. I rebuilt one and it was fine, rebuilt a second one and it leaked worse.
rfletes79
637
127
Galt, Ca 95632
You need a new filter head or rebuild the one you got. It's losing prime, this happens to all duramax's with OEM filter heads over time.
