So, has anyone ever looked at putting in a secondary set of piston oil squirters in the block? Is this an issue we should even look into? My thoughts on failing pistons are similar to many others in that the cause is overheating them and I believe extra oil for cooling would be a helpful assistance in controlling this problem.
When we put Simon's engine back together I was looking at the oil gallery where the stock squirter is and it doesn't look like it would be too difficult to tap into it and install a second one. The only thing is that you may need to upgrade to a hi-flow oil pump to keep the flow/pressure up but that is a minor detail IMO.
Am I off my rocker here or what?
Open for discussion:
