Question: Seat Removal
GMC_2002_Dmax
The Still Master
I want to take the seats/carpeting out if my 2002 and 2007 to clean the interiors really well, the problem is the funny nuts and bolts need a special socket to remove them, what is it, where do I get it ???
Also, the shifter cable goes thru the floor, easy to remove or no ???
Spring is coming and I want some clean trucks, so any help advice is appreciated.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Yeah the seat and seatbelt bolts suck, you can use an Allen wrench but it boesn't work the best I have done that before, or I will go to my local Advance auto parts and they just rent you the tool cheap.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
come on Tony after all this time you still dont know how to take the seats out??? :p:
its not any special socket. Just use a 12 point...13 or 14mm? Yes I know its a funky looking nut, but a standard socket grips it just fine without stripping it.
ben
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Gald to read this, I am going to install a laptop mount soon in the truck. I was eyeballing the seat mounts wondering if I had something to get them out.
Thanks!!
ripmf666
15,123
14
47
Wentzville Mo
Thanks!!
The ram mount is a easy install,It mounts to the underside of the seat and moves with the seat if you slide forward or back.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
I've got a jotto desk layin around that came out of my last ford e350 van. wouldn't fit it the express van but I think it will work in the truck
Posted via Mobile Device
SBCNX20
Junior Member
Aug 7, 2006
354
53
Central MA
Tony I just Vacumed my truck yesterday:barf: and decided to just buy a new carpet, it is trashed! These New England winters are a Killer. With two kids that play Ice Hockey the poor truck gets killed inside!
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Use an 11mm 6 point socket on the bolts
Use a 15mm 6 point socket on the nuts
18mm does the back seats nuts on exteneded cabs
I took mine in and out about once a week all last year and they never got at all stripped using 6 point metric sockets.
Cougar281
1,806
249
St Louis, MO
Here's what you need for that nut. My E18 wouldn't fit on the nut, but I think the nut is an E18 and the bolt was too long for my socket, so I think a E18 deep would do it.
othrgrl
Mar 10, 2008
2,151
Wilmington NC
12 point? What size?
As I said simple 11mm and 15mm 6 point sockets fit fine, no need to buy more tools. I used 1/2 drive with a 1/2 universal and an extension hooked to my cordless impact. The front seat takes longer to carry into the house than to take out.
