Season video
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
Here is a compilation of the year in pulling. You guys have probably seen most of them through my other posts. Thank God for some better luck or I was done pulling for a while, if not for good. Things started coming around at the end of the season after we changed the housing and added the Ally locker to unlock in 4th, and some good tuning help from Diesel Pilot. Not bad for a small 2.6 compared to most, 45 over injectors, stock gears, single rear wheels, and a compression ratio that most thought could not make any power.;) Factor that in to us pulling in one of the hottest areas in the country for 2.6 trucks.
Got some more big plans for next year. First order of business is see where my copper gaskets are leaking. Need to do a compression test and then get the heads off. Might move the turbo slightly from there to shorten the piping so we can spool a bigger and better spinny thingy. Change gearing, bigger sticks, air to water, ....:thumb:
Might even add a front bumper.:D
Thanks for the help to all those in my signature.
[YOUTUBE]ZRC7iN_GRQY[/YOUTUBE]
05smoker
Mar 30, 2007
2,379
Lebanon, OH
any updates on the new setup for 2011?
Got my new tips back from extrude hone. Motor is out and sitting at GMS. We are pulling heads this week. Still researching chargers, piping and air to water but got some ideas.:secret:
Once it's together and on a dyno, we will decide 4.10s or 4.56.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
:thumb:with all the power 2.6 class is making and if your staying with 33's 4.10's might be the best for you. the dyno will tell you were you need your r's for track use though
