I finally got around to testing the twins for boost leaks...WOW. MASSIVE air leaks around where the stock turbo inlet seals into the stock LLY turbo. I could hear air rushing through even with the radio on in the shop. The twins must move some serious air if they could make 40psi with that big a leak.
Im looking into buying opie's inlet, but until then, any ideas how to get it to seal better? Throw some RTV on the mating surfaces??
I know its not designed to hold boost, but before opie made his cast intake, the twins kits just used that stock piece and it seemed to work OK...
ben
ben
