I know most of you are going the other way (down) with your trucks but I went up a couple of weeks ago. I put on a pro-comp 6" front 4" rear lift kit. Everything went good until about the end. With my SD centerlink, my tie rods run straight out to my tires (which I think is a good thing)! The problem is, once I put my sway arm on, flipped over like the instructions say or I even tried the factory way, it hits on my tie rods. I can see if I had the stocker centerlink on the bends in it would allow the sway bar to clear, but it wont with a straight centerlink. So far I have been running without the sway bar. I am thinking of welding some plates on the front drop/crossmember that came with the kit and position it that way.
Has anyone else had any experience with this?
