Running scripts on LB7's can drive you bonkers. I know it has driven me up the walls as some tables will be different in different OS's. And when you create a script, it will only make the changes from the base tune to the modded tune you made the script off of. I know that some LB7's use different torque based tables and a few others, and those tables won't always make all of the needed changes. For LB7's I will run a script, but I will also go through and manually compare every changed table as a lot of times there will be some weird peeks and valleys after the script.
