This is my wifes truck a 04.5lly.
Some history on the trans, The trans i bought used allready put together and in working order from Adam (Turbobeaglebuggy). I did switch to a ats 5star converter only because i felt i damaged the 1057 during install adn i didnt want to risk junking the trans if i did f up the converter!
Anyhow mostly the 3/4 shift is the worst but the 4/5 is kinda rough also. during 1/2 throttle and above it will launch stuff out of the cubby holes duing a shift and even chirp the tires on occasion. 1/2 to 3/4 throttle is the worst, full throttle actually smooths it out a bit. You can feel the whole truck shudder when it like this as well, to me its almost like its shifting with the converter locked. Ive tried different tuning methods (engine only) to make it shift better with no luck. IMO these shifts are far harder then should be. So i guess my question is, is it normal for them to shift this rough or is something haywire and gonna start breaking hard parts.
Thanx,
Caleb
Thanx,
Caleb
