So I had to pull my rail to get my FPRV out, so I went ahead and ordered a race valve becuase I figured I would screw up the shim.
So its doing the same thing again when I put on my 500rw tune it will go WOT with full pressure for about half a second then drop below 100mpa and when it gets to high rpms it starts to do a rev limiter surging kind of thing, and again it isnt throwing any codes no 1093 or 94s.
I guess tommarow I can try to tighten the race valve some more becuase I had it at what I think is about 60ft lbs which is what ppe says to torque it too. I also cleaned the threads of the rail with a q tip and some ether and put some vasoline on the valve and torqued it down.
If I go ahead and shim my stock valve will it be ok to torque it to 60ftlbs to becuase I don't know how much I can put on it with damaged threads and the rail in the truck?
