Help: Safe for Full reflash?
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
I am set to flash in my DSP5 operating system. I don't have a bench harness and documentation strongly advises isolating the ECM from the class 2 network with a star connector (?). I'm searching for solution but can someone advise me? Thanks, Rod
LBZrcks
Jun 2, 2007
5,297
12
SoCal
I've never done anything special. Just click the full flash and make sure radio,lights, etc are turned off.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Shut off radio heater anything that drains power
I've done hundreds of full flashes and only killed one ECM
u should be fine
Sledhead
Nov 29, 2008
884
BC
The full OS and calibration option is disabled. It will let me read pcm, flash the calibration, but not the OS and calibration.
I upgraded my OS very carefully following the instructions and confirmed the right script (late LB7 metric). I used Socals scripts to populate the tables from different tunes. Is there a permission I need to enable?
LBZrcks
Jun 2, 2007
5,297
12
SoCal
The way I normally do it is key on, plug in V2 to truck, then to laptop and open the efi live program. There are features that aren't available unless you have the V2 plugged in prior to opening the program.
Sledhead
Nov 29, 2008
884
BC
Do you have the V2 plugged in before opening efi live?
Thats all it was. New OS and calibrations are flashed. Truck runs fine but I didn't notice any change (at idle) from tune to tune. I'm going for a drive...
Sledhead
Nov 29, 2008
884
BC
It seems to be working, the tunes are pretty similiar but I put a smoke tune in the last calibration and it smokes on that one lol. Set an overboost code on at least one of them too, 28.5 psi on my max hold guage. I'll need to fix that. Thanks for the help :hug:
