s491/100/1.45 Forced Inductions
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
Josh had to break my arm, lol, but we're trying out Forced Inductions new 91mm s400 with a 100mm turbine wheel and 1.45ar housing. New setup will be an sxe 472/87/1.0 with the FI 491/100/1.45. Should pair very well for our goals. Can't wait to see how it does.
The 369/74/.91 ended up being too restrictive for us but had decent street manners with the s488.
Sent from my SM-G930V using Tapatalk
3,727
296
Should be a beast! Let us know how you like it, and how it spools. I'm very interested to know if it works as well as I think it should.
Sent from my Cat S60 using Tapatalk
coker6365
Dec 4, 2011
486
Nice! cant wait to see how it performs on a duramax! what kind of fuel you gonna push it with?
Running 250% injectors from F1 with Exergy 10mm and Sportsman pumps. Should be plenty of fuel to test the air.
brokesmoker
141
Virginia
I have the FI s488/100/1.32 with an s472 with 250 overs I need to upgrade pumps, curious to see your numbers. Nice build btw too
coker6365
Dec 4, 2011
486
472/87/1.0 sxe? How do you like it so far? We will be running non gated with a divided pedistal to help spool. We can always add a gate later if needed.
brokesmoker
141
Virginia
I like it so far I had rail pressure issues so far so don’t really know my potential honestl, I talked to FI and I got a billet 75 to put in place of the 72 so we’ll see how it goes.
coker6365
Dec 4, 2011
486
Gated? And I am guessing that's an 87mm turbine on the 72. I don't see the 72 being a limiter with the 88, but I am sure the 75 will help a tad.
brokesmoker
141
Virginia
Non gated and yes 72/87/1.0 but after talking to the guy at FI he thought it might do better with the 75 so we’ll try it and see I’ll keep the 72 till o see how it goes
coker6365
Dec 4, 2011
486
Gotcha. Keep us posted. Nice build too!
coker6365
Dec 4, 2011
486
Sorry guys, it's been a while since I have updated progress on this charger. The 472/87/1.0 paired with this 491/100/1.45 has performed well above our expectations. Spool up is not bad after swapping to a Goerend J converter. Drivability on the street is decent. Power is phenomenal.
In Denver on the ATS Mustang dyno, we made 1193hp/2314tq uncorrected and 1487hp/2885tq corrected running a 2500us tune paired with 52 and 88 jets for roughly 175hp worth of nitrous. The DA was around 8000ft if I remember correctly. Drive pressure logged was 1:1 until we were over 4200rpms. I would say this is about as good as we can hope for and we still have room to grow.
Fastest pass to date is a 10.19 @ 140mph on a 2000us tune fuel only. I believe we have a decent 9 in it once we turn the wick up and spray it down the track.
coker6365
Dec 4, 2011
486
Absolutely, LML block has been sitting and waiting for a celebrity shot. :hug:Not sure if we will half fill or not at this point. Consensus is to leave it alone and run it.
coker6365
Dec 4, 2011
486
No clue, but I would assume it is an LML block or equivalent.
Sent from my SM-G965U1 using Tapatalk
