s472 install checklist
Dirtymaxx03
3,109
im gonna be doing my install next weekend and just wanted to to get some second opinions on everything i have to make sure its all there.
s472
pedestal
downpipe
oil return and feed
intake
coolant crossover plug
plug for stock oil feed location
T4 gasket
what else do i need. i think im missing one more plug for the coolant line...??
LBZrcks
Jun 2, 2007
5,297
12
SoCal
I actually just bypassed the hose together on mine. What about the down pipe and the IC tubing?
Dirtymaxx03
3,109
i forget to put downpipe in there. i got that covered. and i have a friend helping me fab a reducer so i can use the stock IC hose. im mainly just worried about the plugs
Dirtymaxx03
3,109
im aware of the tuning. im expecting a CEL cause im gonna be running a 5'' intake. that cel shouldnt change performance should it? cause i will have the turbo on about a week before its re-tuned
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
its going to be one laggy bitch
i put a 5 inch intake on mine without retuning and its was less than desirable to drive it to say the least... i would get it retuned asap
Dirtymaxx03
3,109
i planned on trying to get it re-tuned as soon as i can. so recalibrating the maf is a pretty big deal?
durallymax
Apr 26, 2008
2,756
Under The Hood
if your bored you can remove the water pump or y bridge so that you can weld the turbo return line shut at the source a lot of work though, nobody sees a bolt just sticking in the hose that goes to the factory turbo.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Get a hold of Renomax on here he got me a plug to go where the stock coolant feed lines comes out of the top coolant pipe. Looks alot cleaner. :thumb:
