s400 parts needed
dmax711
Mar 4, 2011
1,057
concord, north carolina
Racepartsolutions.com has lines. And your better off cutting coolant port out and welding it up so a 5" intake will clear it. Or merchant sells a new coolant pipe I believe.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Dirtymaxx03
3,109
Merchant for the lines for sure. They have a drain line that has a quick disconnect in the middle of the line, i wish i would have got that one. Would make life way easier. Talk to Henry @ creatures of the night for the ATS downpipe. He HOOKED me up on mine.
07metallicgreen
Nov 24, 2011
207
Smicksburg, PA
thank you for all of your help guys I really appreciate it! I just got my turbo today. I have a y bridge, rdl pedestal, merchant oil lines and dipstick tube, ats downpipe, and coolant plug. im going to try to fab up my own intake and intercooler pipes so that is off the list. all I need is the boots for them. where is the best place to get them? napa did not have 3". also what bolt are used for the turbo to pedestal? once again thanks!
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
You can order up some studs for the ped from BD.
07metallicgreen
Nov 24, 2011
207
Smicksburg, PA
what are you guys using to block off the small coolant return line on the turbo? I have a plug for the crossover pipe but I don't know what to do with the one on the passenger side
