Rut-Roh
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
All of a sudden I have the overflow tank backing up after I shut the truck off & I can hear a gurgling sound in the upper radiator hose. It last at least 10 minutes after it's been off. Logged temps never go over 199. Tell me what I think I know. :( Oil is clean
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
Soft because the water pump started to weep out of the hole this after noon, so I had the cap loose. BUT I heard the same thing yesterday & the pump was NOT weeping then.
The package arrived also today. ALL kind of suprises today
Bluemax
Sep 25, 2006
846
Missouri
Sounds like what mine did when I had an o-ring on an injector cup leaking.
Hope that' gives you something to hope for. Head gasket will make the reservoir black I have always been told.
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
I had the problem when my threomost state wouldnt open. Bought a new one no more problems yet. But it may be a differnt case for u.
2wd_Sled_Puller
Feb 19, 2008
1,356
Florida
Pull dipstick your crank will be full of fuel or have fuel in it. If you take a blue light and shine around your heads and intake that will tell u if you have head problems. If the truck didnt run hot i dont see where the head would be a problem. Unless its from that massive turbo u have:D
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
Remove all eight glow plugs. Let truck set overnight. Open hood and have sombody crank the engine over. Check for fluid coming out of glow plug holes.
RickDLance
1,276
14
O'reilly has a rebuilt water pump for around $40. Blowing the seal is a common sign of extra pressure in the cooling system. :( Lets hope it's just a coincidence.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
A) Move to Hard Parts.
B) LB7 or LLY? LLY's don't tend to have head gasket problems as often as LB7's, unless they have overheated. But water pumps are very common.
C) Is there any coolant underneath truck?
LB7Diesel
Oh Boy!
Sep 3, 2006
1,355
Melbourne, F.L.
:yup:
I couldn't get all 8 out. I could only remove 6, but it was enough to let me know my shit was screwed.
Hopefully it's not head gaskets. I'm sure your ready to install your goodies:eek:
Bluemax
Sep 25, 2006
846
Missouri
I didn't have fuel in the crankcase, I had coolant.:)
Bluemax
Sep 25, 2006
846
Missouri
How would you diagnose that?
I did it with the glow plus out like Dan said. I found the problem from an oil sample originally though, it read that it had some coolant in it. I had been losing coolant for quite a while and couldn't find where it was going so I assumed it was out the exhaust. Got a little smoke sometimes at an idle.
