So i'm stumped kinda. Been messing around trying to figure out where the fault is that's causing my left side running lights to work (any running light feature, the 194, the 3157, and the left side license plate light) Also, idk if it helps but the 194 and the 3157 blink at the same time on the left side, rather than blinking sequentially like they should.
Anyway, I tested every wire in the harness to the tail light, everything works fine
I thought I had power going to the junction box, so I replaced it today.. Turns out I don't have power to the junction box. I keep loosing the wire because there are two looms back there and I don't see how they hook up. In the middle of the truck there is some kind of little can looking thing that I thought went straight to the junction box but it doesn't. However I do have power to that brown wire.
I'm hopping someone has a schematic or something so I can see where that wire goes. It looks like it goes up in the frame and the other loom runs down the side of the frame. I know the brake wire goes up in the cab and connects under the dash, so I'm curious if the running lights do the same..
Forgot, I checked all the fuses and everything is fine there..
Thanks.
Thanks.
