Something that was brought up here : http://www.duramaxdiesels.com/forum/showthread.php?p=277081#post277081 and I think it is something worth discussing.
Why couldn't we put something on the discharge side of the compressor with a smaller hole in it to keep back pressure against the compressor side of the turbo? It would be a little tricky to figure out what size of hole would be needed to maintain some pressure but by doing this we should be able to keep the turbo from overspeeding no?
This is so you can run in a single turbo class without having to remove the second turbo.
Thoughts........
Thoughts........
