Allison 6sp: running 3600 rpm shift points on stock tran
walsh450mx21
MR. MIDNIGHT
Aug 28, 2007
152
FLAWIDA
So im tunning my truck tomorrow with my old lbz tune pat and neens built for me.. But i have a trans tune from kat i would also like to run with 3600 rpm shift points. Can i run this tune on my stock trans. I know its going to frie either way but will this trans tune make it happen faster or help it at all.
Thanks
Tyler
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
i made my own that shifts at 3500 at wot and its holding up well. i think the higher rpm power is less stressful on it because there is less torque up there.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
X2 the trans would be more likely to be hurt in the lower rpm's when torque is its highest IMOP .
15,681
233
If you are straining the trans the ECM will subtly pull back power. You may not notice it but it will show in your et and speed.
9,905
151
I run 4th gear up to 3800 rpm on my stocker. Haven't broke anything yet.
Dec 2, 2006
1,696
TN
Dumb question from the EFI newbie here.
But, where do you actually raise your shift points? Or if anyone has a tune for me to look at that would be great.
rgullett83
1,607
Illinois
X2, and in my opinion the stock trans may live longer this way, but that is just my opinion.
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
I would worry more about EGTs than the trans when shifting up that high. When I raised my shift points the trans shifted great but my EGTS went from 1500* to over 1750*.:eek:
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I dont get why you guys fry your transmissions before you build them? There are more parts in there that get damaged by heat than just the clutches...expensive parts.
walsh450mx21
MR. MIDNIGHT
Aug 28, 2007
152
FLAWIDA
Because when u got 3 extra stockers laying around.......... WHY NOT.............
idk about other but this si my case. Im slowly getting cash together for my build. hopfully by the end of the summer itll be ready.
Dec 2, 2006
1,696
TN
Because you build trans for food, so I can get my done cheaper. I'll buy you a steak...
