Rpm limit
YoungGunDiesel
Jul 19, 2017
45
Not sure if this is the right place but are you able to rev your duramax while in park? Mine reaches 1500rpm then stutters and falls back down. Never exceeds it.
2006 Lbz
Sent from my VS995 using Tapatalk
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Something is wrong. Should rev to the limiter. Which is around 3200 stock
YoungGunDiesel
Jul 19, 2017
45
You have problems get a good scan tool on it ASAP , prior to anything bad happening ! Good luck!
Thank you, any recommendations on a good scan tool? Mine does live data and the code I currently got is for u0100 and another for a intake temp sensor 2 (but that's cause its currently broken)
YoungGunDiesel
Jul 19, 2017
45
Well the truck isn't on the road so I won't be driving it, sorta just a project truck to learn on
