i just did a headgasket job by myself on my 04.5 lly and its back together now and running, except its very rough after the first day out working out the bugs. while i had it apart, I swapped chargers to a 68mm fleece cheetah vgt, and billet push-rods. And now for the problems listed;
1. My first problem is my banjo bolt in the valley of the motor is leaking and i cant get to it, are there any ways to get to it and not take the turbo out? because the turbo took more time than anything
2. At idle and mid throttle it misses and shakes. even going down the road around cruising speed at 45mph at 1400 rpms it will shake you in the seat. what could this be? It almost sounds like an injector isn't firing.
3. At the lightest touch of the throttle it smokes like a train almost like an injector is sticking in the open position. i have checked balance rates and they are fine. today was the second day it has been running and it builds boost fine and stays decently cool.
Any help would be much appreciated to help get my rig back going. I am near Godfrey, Illinois so if anyone is near i might need advice or a good shop near by to get the small stuff done. my number is 217-248-8116 if you can reach me easier there. Thanks !
