rough idle and smell raw fuel
priddy
Aug 6, 2015
OK I am working on 2003 gmc 3500 lb7 had bad injectors replace all found passages side head bad replaced it and new injector cups and but it all back togather and now I have rough idle and and can smell raw fuel again it started when I took the truck on long test drive for about 30 mins is when this happen before it was fine I need some help could this be a bad fuel pressure sir or is there anything else to check thanks
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Have you run the engine with the valve covers off at max rail pressure to see visually where it's leaking yet?
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
If the raw fuel smell started though from right after you started the truck, I'd be looking at a reassembly issue on the fuel return side of things.
priddy
Aug 6, 2015
It didn't start it until I took the truck on a 30 min drive because right after I got done it cranked just fine and ran just fine with no problem
