rotten egg smell
Barlow
Barlow
Apr 19, 2009
120
Mississippi
I had to jump off my truck yesterday... third time in two weeks! So after jumping it off I went and met a friend and sat and talked in my truck letting it idle for almost an hour and half mainly cuz I was scared it would be dead again if i shut it off. After that the passengr side battery was stinkin bad. Does this mean I need new batteries?
Brian1
Jan 1, 2008
103
Yep bad battery. Replace both at the same time. No sense leaving the other if old killing the new battery when the the one you leave goes bad and takes the newer one with it.
Brian
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
If they are the original batteries your way over due especially if they are AC Delco's. But IF your smelling a odor like Rotten Eggs it could be a sign of over charging and cooking the battery.
I would check the voltage system out to ensure you don't cook new batteries.
03maxpower
Jan 20, 2009
327
somerset, pa
that egg smell is the battery leaking i thought i ran through some sewage when i first smelled mine thought it would go away but never did thats when i figured out it was the battery. new ones for sure
