Hi!
I want to rotate on 180deg 261 or 263 transfer case. If I weld or close upper holes and do something with oil pump will it work?
What do you think about this?
Hi, Bill !
Yes, conversion with patrol transfer much expensive than using GM transfer.
As for me, I need only custom Allison output shaft. Other parts I can made by myself.
But I do not want to make new shaft and cut splines.
I found that NP271 (Ford version) transfer also may be used with Allison. It is the strongest transfer, and It has a fixed output yokes.
But wight is too much- 120lbs vs 77lbs for GM.
I know that Allison output housing is weak. Will it hold heavier transfer?
The allison output will hold a 271. I have been running a 273 for the past four years without any problems what so ever. 271/273's are bigger and heavier. Not sure how much room you have.
Why not run an np205 from an older gm?
