The material thickness of an 1 3/4" 5 point roll bar needs to be .083 (4130 chromoly) or .118 (mild steel)...The 5 point bar good till 10.00 as long as you're slower than 135 MPH...A 1 5/8" roll cage has the same thickness specs...
Thanks Paul
On a reg cab will it have to go outside the back of the cab?
This is all 100% true, just thought that I would add. When building a bar or cage, one usually uses .134 wall tubing for MS and the chrome is somewhere in the .9* range. This is so that it doesn't go under spec when you bend it and it thins on the outside of the bend. Also when you go to a cage not everything has to be 1 5/8, some bars can actually be smaller and can be thinner tubing.
Not to be a thread hi jacker sorry simon. But say someone would want a soild 10 sec truck what are the cage requriments
Good point Paul...That actually bit me in the behind over 10 years ago...
