Hi, I have a 2008 GMC Sierra 2500 HD 4x4 Duramax and my brake light, blinker and running light on the rear passenger side is not working. The back up lights work. I have checked all fuses, replaced all the bulbs, replaced the rear wiring module and the harness from the module to the right tail light. All this is done and I have the same results. So when I turn the right signal on, it flashes 3 times normal and then hyper speed after that. have check to see if there is any voltage running to the harness and it is a little bit less than the driver side. I have heard there is a relay under the dash that might fix it. But I can not find that. I have ordered a new brake pedal switch, the cruise does not always work either, and read this could make the tail lights act funny too. Thoughts?
Thank you
Thank you
