Reverse
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Shift range inhibited in reverse.... Any idea why??
edit: no codes.
13,716
779
Got anymore info? When does it do it? Does it throw any codes? Have you done anything to the trans lately?
I had a reverse problem about a year ago, and it turned out to be a problem with the pressure switch manifold that bolts to the valve body.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Take it to MikeL he can fix it
Why are you such a dick on here. get lost. Your a waste of peoples reading, yes a waste. You wasted my time in PMs, and you waste everyone elses time with your non needed posts.... Get teh hell outta here looser.
Wes, did this happen right after startup? did you grab reverse pretty quickly? or just normal driving, went for reverse and it wasnt working?
Did the condition go away?
whitetrash21
Apr 29, 2008
4,929
Vegas
Truck is stock. Except for pipe, intake and bigger tires, nothing else done to it.
I was backing up out of a parking spot, truck made it about 5 ft and then just stops, like I backed into something. Check the mirrors, nothing there, look down to see if I might have bumped it into park and its flashing the "shift range inhibited" at me. Put it into park, wait couple secs and put it back into reverse, works fine.
30 minutes later, same thing backing out of the driveway. Shifts fine when driving and nothing feels like its sticking. I'm pretty sure I wasn't grabbing it too fast. Every Alli truck I've driven usually has a delay when moving from Park to Reverse or Drive so I've learned not to switch gears and pedal it too fast.
Trans fluid is still red, checked this morning. Doesnt smell burnt. Gonna change filter, see if that changes anything.
still no codes.
beach_33
704
des moines, IA
have you actually hooked a scanner up to it to see if there is a code or are you just going off the check engine light. mine has had codes but no light before
whitetrash21
Apr 29, 2008
4,929
Vegas
Used a handheld. Quadzilla programmer. However, it wont show some codes. We hooked Mikes EFI up to my old truck and there were several body codes and one abs code that never showed up on the Quadzilla.....:confused:
whitetrash21
Apr 29, 2008
4,929
Vegas
Yours was a hard part that failed?? Was your truck/trans stock at the time??
The Neens
BFD
4,596
Monrovia, Ca.
i would check with a better scanner
Wes, can't help right now, but I'll be up there on the 14th and I'll bring my TechII if you wanna try that...
13,716
779
My problem was only after the trans was warm. The trans was not stock. I damaged an o-ring on the pressure switch manifold when I rebuilt it the first time, and I think that may be what caused my problem. When I was having trouble, it just flat wouldn't go into reverse.
whitetrash21
Apr 29, 2008
4,929
Vegas
Thanks guys. Gonna try EFI, and maybe T2 if you wanna bring it chris. Thx.
I swapped the spin-on this morning and it hasn't done it since, but I'll hold judgement for a few days, make sure it doesn't do it again.
whitetrash21
Apr 29, 2008
4,929
Vegas
~360 miles between now and then and hasn't acted up yet.... Still gonna try to pull codes (if there are any) but, without that, anyone think a dirty spin-on could cause this. Sliced it open, looked about like any other 10-12k mile spin-on.... dirty, but no metal shaving or foreign debris.:confused:
whitetrash21
Apr 29, 2008
4,929
Vegas
Used EFI today, checked for codes. Same thing.... couple bcm codes, one abs, one tranfer case (u1009 or someting like that), but nothing trans related. Up to 490 miles now since I swapped the spin-on and still running fine.
I guess I can hope its minor, maybe the filter :confused: ..... Just drive it for now.
