I'm going to the track tonight to play with some TCM tuning. I'm going to start out with a 1st gear delete tune, run a couple of different ECM tunes, then reflash the TCM to use JoshH's "early converter lock up tune" using all 6 gears.
Question is, do I need to reset the taps after flashing to Josh's tune? Am I risking grenading something if I go out and immediately make a hard pass right after a TCM reflash, or just crappy shifts?
Finally, if I need to reset the taps, how do I do it with the DVT tab in EFILive. Running 7.5.4, so I've got all 4 boxes at the top of the screen.
Questions, comments, advice, donations,.......?
Thanks!
Thanks!
