Reposting for my brother, any help is appreciated.
Hey Guys,
Having weird issues with my LLY and after trying an injector, feel I need to come back and ask for some help. Did my Head Gaskets earlier this year. No trouble and did studs, grade c gaskets, and otherwise just checked it all over. All good for 4 months. Now new problems.
Truck has 330,000 KMS, and is an 05 LLY ECSB. Most Modifications in Sig i think, if not just ask and I'll answer.
First about two months ago, I blew the return line on Injector 6 right off. Not sure if Race Plug could cause this? Replaced with new Injector Clip, worked good, never blew again.
Fast forward a month. Truck gets a pretty good shake at idle and has a miss, and Injector 6 Balance Rate runs around 13-14 all the time. Try some cleaner, lowers to 9-10, still rough at idle. Decided that the injector was bad and that was the reason for the excessive fuel return, rough idle, and poor balance rate. Order new Reman injector from GM, install tonight.
Fast forward to the drive home. Truck has continued rough idle. Balance rate is 8-9. Thought I'd drive home and do some more research. Half way home it now blows the Return Line off Injector 8.
Could this be Ice Pick? Still haven't tried that. Any advice is appreciated
Hey Guys,
