Question: Replacing steering wheel and inst. Bulbs
ToyhaulerTom
Old Tom
Jan 1, 2015
58
Southern California
Does anyone have info on replacing the light bulbs in a 2006 Sierra SLT that illuminate the controls on the steering wheel, and those that back-light the fuel gauge? I just want to replace with the normal bulb. I have several burnt out.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
They are led and soldered in.. It's possible just not fun or easy
schulte
Jul 31, 2010
449
CT
The steering wheel ones are not LED.. they're regular 12v incandescent. It's cheaper to buy the whole button assemblies than it is to try to replace them if you just want stock backlighting.
If you want to replace them with a different color, you need to solder LEDs in their places and put some resistors in the harnesses.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
O ok I thought those were led also. Thanks!
13,736
806
The cluster has regular bulbs also (soldered to the board).
schulte
Jul 31, 2010
449
CT
Correct.
The only ones that are already LED are a few of the smaller ones in some of the door switches. Everything else is incandescent. Dash, 4x4 switch, headlight switch, HVAC, radio, etc.
56taskforce
1,081
56
^^^^^ and they can be found on eBay. The wires are short and can be a PITA a pics of dental floss works well to pull the wires securely into the plug on the new switch as it is pushed into its hole.
Oops this post was ment to be below schulte's first post
