While swapping motors out, I had one of the clips on an injector plug break when released, and I looked around to see if I can buy a new plug and simply unpin it and replace the end, but I don't see any information on this. Does anyone here know for sure if these can be unpinned from the rear, or are they the type where you slip the wire through, crimp the pin and pull it back through. If this is the case. where can I buy replacement parts for the injector plugs. I hate to cut and solder in a new pigtail harness, but I will if needed.
Thanks in advance for the info. :thumb:
