LB7: Replaced FPRV now has loping idle
20chevy04
Aug 17, 2011
295
Stuart ,FL
Hey guys so I just replaced my FPR and now at idle with my stock tune on it lopes an check engine light comes on. When I drive the light goes away and runs fine. When I stop again it comes back on. Also if I turn my dsp5 to any other tune it does a crazy loping and lights comes on. Any ideas?
20chevy04
Aug 17, 2011
295
Stuart ,FL
I was only able to swing by auto zone and have them hook there scanner up which only pulled the code didn't tell me what it was running at. Also I replace it because it showed the code and also had a rough idle even after adding the 2 stoke that I've been doing for 3 years. The issue started about a month ago I would be running with my tune on an start slowing down to an idle an it would sounds like it loping so I switch it to stock mode and goes away.
NRA223
May 20, 2015
288
The issues before you replaced the Fuel pressure relief valve sound like a fuel pressure regulator issue.
buschmaster1
Feb 2, 2016
5
grand junction
I agree with NRA223.. HAVE HAD frp sensor wires rubbed through causing this issue but if wires are okay the regulator valve is most likely faulty.. p0089 which is a pressure regulator performance code. is generally pretty common for replacing regulator valve
buschmaster1
Feb 2, 2016
5
grand junction
have also had quite a few regulator valves malfunction in the industrial injection "bag o parts" cp3 kits as well. keep in mind. just because its "new" doesn't mean its good!
NRA223
May 20, 2015
288
What buschmaster said. My original fpr went bad after putting on a lift pump that was set too high. The brand new in box Regulator that i got to replace that one was bad out of the box.
