LB7: Replace 1 Injector or All 8???
Sep 10, 2008
1,072
Morehead City, North Carolina
Injectors were replaced approx 50k miles ago under extended warranty. Injector #2's rates are out of spec. Thought of just replacing one injector since others look okay. Is that a safe idea? I've spoken with a few people, one included who did the same thing then ended up with 3 cracked injectors and 2 BENT???? Ended up having to replace all 8 said if you do one do them all at once. Kinda don't have the $$$ right this second. Opinions? :confused:
custom8726
2,784
Upstate N.Y
Injectors can be trickey, They will compensate for each other. You might be able to get away with changing just one, but it might just throw a different Balance Rate out of wack. That said I would try replacing the problem injector first and then go from there. What was the B/R??
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
tough spot i know! i think we've all been here! as easy as it may seem i would replace all eight, or at least the four on the same side. i have learned alot of lessons here lately!
1chevy02
Jun 23, 2009
504
so whats the verdict on this i have # 8 + 3.8 and been hearing the familiar tic all the others seem fine:mad: replace one or all?
1chevy02
Jun 23, 2009
504
I will leave it for now but Iam just wondering what is best to replace just the one or all 8 the others are close only # 2 is -2.2 and #8 is +3.8 and it is just getting a LOT louder again
1,696
TN
I wouldn't risk it personally. I would do all 8. It would be different if the LB7's injectors had a good reputation.
