does anyone have any good links to diy for removing the dash in a 03? ive got to change my evaporator core....oh joy
I know it doesnt help much. Sorry. Maybe someone has access to the body manual that can email you the right chapter?
- Remove the I/P trim panel.
- Remove the center console, if equipped.
- Disconnect the negative battery cable.
- Remove the driver side knee bolster.
- Remove the lower I/P trim panel.
- Remove the passenger side air bag module.
- Remove the radio.
- Remove the HVAC control.
- Remove the accessory switch housing.
- Remove the left air louver housing.
- Remove the steering column.
- Remove the communication interface module, if equipped.
- Remove the remote control door lock receiver module, if equipped.
- Remove the data link connector from the I/P.
- Remove the park brake release lever from the I/P.
- Remove the I/P cluster.
- Remove both front window air ducts from the I/P assembly.
- Remove the harness from the I/P.
- Remove the I/P assembly retaining bolts (3) and nuts (4).
- Remove all harness hold down retainers from the I/P assembly.
- Remove the I/P assembly from the vehicle.
IIRC there are 10 screws that hold the dash panel in. 2 in each of the bus panels, one in the driver A/C vent, 3 behind the cluster, 2 behind the radio, and one in each of the passenger A/C Vents.
After removing all of those, pull gently as there are several clips that hold it down by the windshield. Do not forget to unplug the sensor on the dash before getting all happy and pulling the dash cover out.
If you are looking for the duct actuator, good luck it's buried under more tubing than you would imagine could be under the cover. 1/4" drive ratchet and flex the plastic duct to get the screws out.
