LB7: Removing E Brake Cable
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Does anyone know how to remove the E brake cable off of the rear differential? I am doing a rear end swap and that is all that's left one one rear end.
03spoolindmax
Nov 9, 2011
674
Mi
I use a pair dykes(no pun intended) to get In between the spring and bracket. Then use the dykes to push/pry the spring away from the bracket. Then slip in a pair of long needle nose for leverage and push the spring until is passes the end of the plastic. Once you get the spring past the plastic you can hold it there with the dykes slightly clamping onto the cable. Then use the needle nose pliers to push in the 2 tabs and wiggle it out of the bracket.
