Anyone have a good way to keep the crank from turning so I can remove the bolt and balancer while the engine is on a stand? Wanting to change the water pump again while the engine is out of the truck. I realize now I should have done this before I pulled it (using the Lisle flywheel tool through the trans access hole), but either way it's already out. I guess if I need to I can wait til the engine goes back in then do it, but I'd prefer to do it on the stand if possible.
Also, I've seen some threads saying it's ok to reuse the stock balancer bolt, and some say that it's TTY and needs to be replaced. 2005 LLY, anyone know for sure? I've already R&R'ed it once.
