Remote Vehicle Immobilizer -
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Browsing the gm upfitter pdf on the express van I see there is a 'remote vehicle immobilizer' DIY add on.
Anyone done this?
Is it as easy as it looks? - tap a wire, add a switch, and run to 12volt +.
Looks like it allows you to have vehicle running, but it won't come out of park unless you flip the secret switch.
Page A-43 of the 2012 express van electrical manual on gmupfitter.com
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
I would think a toggle switch wired to your bitsi solenoid would be easier and cheaper. That would at least keep it from coming out of park. Maybe the interlock does a bit more like limit speed?
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Copied from upfitter.
For applications where it is desirable to leave the vehicle running but assure that it can not be moved an external +12 v signal can be supplied to the shift interlock solenoid assuring the vehicle will remain in park – see schematic and location drawings. Best access is a the steering column connector X-200 cavity D4 tan white 816 wire.
