Remote start doesnt always work
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
I have an 11' lml that is tuned and deleted. with no codes or check engine light, and I have a customer who has a LMM and he said the same thing. 9 times out of 10 mine will start and be fine but one time it will start up and shut down within a couple seconds and not restart with a remote. he said his will only work one time out of ten. anyone run into this? no check engine lights and no codes with either one. any ideas?
15,681
Mine will grind sometimes like the voltage wasn't cut off on time to the starter. I stopped using it.
catman3126
Jul 24, 2012
2,636
NE Oregon
But Mike it is sooo nice when it 102 out and that black SOB is SO hot its a real ball scorcher LMAO. I've heard that too but mine just flashes the light and never cranks. same with the LMM.
15,681
Don't be a meow. My truck is silver and it never gets that hot inside.:D
Awenta
4,090
CT
Solved
Mar 28, 2015
267
Blue Springs, MO
I think usually when it starts and shuts down right away its just a computer glitch. On all the aftermarket ones I have installed its usually having trouble talking to the security system or the tach signal. Im not sure if there is any way to fix this on a stock system. Good luck, I hope you figure something out!
catman3126
Jul 24, 2012
2,636
NE Oregon
No codes, no check engine light, no tire pressure monitoring light, nothing. the only thing I'm wondering is if its has to do with that Dash Logic I have connected to the data port. I'm going to try disconnecting that and see if it still does it. But I know the guy's LMM doesn't have anything connected.
