relief valve bad?
onebaddmaxxx
1,212
Cecil County Md
Since iv had my lb7, it has had low rail pressure. I had an injector returning too much when I bought it causing hard start issues. Replaced that injector and all has been good. running tonys tuning. I sent him some logs and with a 3100 pulse width, it was dropping pressure pretty hard. Around the 17,000-18,000psi range. I bought a brand new lbz pump and installed it with some 45% nozzles at the same time. now with the tuning adjusted, I am still dropping pressure down into the same range. I have good balance rates and command rates. Truck has 260k miles on it. No fuel leaks. Anyone think the relief valve could be bad? I mean realistically is there any other pieces of the puzzle that can cause low rail? Iv read that lb7s have horrible relief valves and that if they pop once, they are pretty much done. I was thinking about putting the race plug in or welding it shut. Any ideas on this?
xtremebikr04
Jan 17, 2011
573
Vermont
I could be wrong but i thought the lb7 relief valves were very stout? If it's not the relief valve being bad then it's your injectors. That's basing the theory your new lbz pump is not returning to much fuel.
9,905
151
At 3100 pw your losing rail with 45 overs? Not surprised. Time for dual feelers or dial back the pw.
Sent from my C6906 using Tapatalk
9,905
151
No In original post you can see it said tuning adjusted after I put 45s in. Now it's around 2500 I believe.
Making "Tuning Adjustments" could mean anything.
I'd plug the relief right off and see what happens.
