Reflashing the BCM with a GM Tech 2
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
My 01 came through with no fog lights, I bought the kit from GM to put them in, I have access to a Tech 2 just wondering if anyone knows if I can just reflash my self or do I need to take it to a dealership? I know you can do some mods to the BCM without a work order from GM.
5,950
What do you want the BCM to do for you??? The light in the cluster???
when you turn the fogs on in a 01-02, no indicator on the cluster lights up. only a little LED next to the switch
I was told it was in the BCM??????:confused:
Its all wired through the BCM. i dont think you will have to flash anything in though. I thought i remember reading somewhere that that already comes in the BCM, you jsut have to plug it all in
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
I believe like when you do need to get the calibration flashed into your TECH II to down load in order to excite the fog lamps.
I do believe I read that before
ripmf666
15,123
14
47
Wentzville Mo
I know my 06 has the wiring in it for the fog lights and the fuse spot. I was looking at the kit and its plug and play add fuse into hole and add switch to dash and change add valance and lights and it will all work atleast on the 06/.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
I think 03+ is just plug and play 99-02 needs something done with a Tech 2 I had an 02 1500 and the dealer had to plug in and turn fog lights on???? Hopefully I can figure it out.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Ya your probably right ,I do recall reading way back I believe on the Page you needed to excite the option even tho it was pre-wired. The later years probably are plug and play
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
yes need tis access and need to download the cal and flash it . if whoever has the tech2 has a tis account then you can do it yourself.
