Reduced Engine Power
ruffmanatv
Yeah, its got a D-Max!
May 9, 2008
3,640
46
Van Wert, OH
Ok, so I put a EGT gauge and a Boost gauge in my truck today. I have everything hooked up, except I forget to hook up the MAF sensor. I remeber this after I start the truck. Kicks a P0700 code, I get that cleared but it will not clear the Reduced Engine Power. I have taken the Tune back out. I cleaned the connection on the MAF sensor, and nothing seems to work. I unhooked the batteries for 15 mins also. :mad:
Any ideas on what it could be? Please help I am stuck driving a gasser.:(
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Try flashing your stock TCM tune even if you are running a stock TCM tune.
ruffmanatv
May 9, 2008
3,640
46
Van Wert, OH
Well I am at work. Friend said he has it fixed not for sure what it was. I will know more in the morning. Thanks for any and all help.:hug:
ruffmanatv
May 9, 2008
3,640
46
Van Wert, OH
Ok so he said it happened again. P2127, . I had MAF sensor off and nothing seems to be wrong with it. Not sure what it could be. It is not throwing the P0700 code anymore. Still getting reduced engine power too.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
P2127 - Throttle/Pedal position sensor/switch "E" Circuit low input.....
If thats any help..... Luck steve:)
NelsonDiesel
Formerly StewieTuned
May 8, 2008
896
41
Buena Park, CA
www.NelsonDiesel.com
check your fuses and check the wires that you tapped into for power for the gauges.
if the pedal is disconnected the truck will do this... maybe a broken wire or unplugged connector.. short... open... could be anything. just go over your wiring and fuses.
ruffmanatv
May 9, 2008
3,640
46
Van Wert, OH
And the winner is....???
Greg
When friend was cutting the grommet to put boost tube and EGT wire through, he managed to cut one of the drive by wire, wires.:banging:
Got it patched up and is working good.:D
So thanks for all the help. Truck is up and running and gauges are working great.:beavisnbutthead:
